I will try to do it, for now I only have photographsDo you have access to a scanner at al?? (for the
That would be fu!@ing great!! Thanks for scanning it in. If you can do 600 DPI and save the files in PNG format. Thats all i need
Any chance you can do the same to the carts PCBs??
There is no rush when ever you have time is fine It does take a while to scan and get them just right. the hardest part is getting them straight on the scanner... I think i have ocd on that
Can you look through my PCB scan list. http://igspgm.com/pcb/index.htm
If there is any cart on there with a "place holder" waiting on scans... Can you see if you have any of those revision?? You should be able to look through the clear red cases and see the revision sticker on the main chip. That would help heaps if you have a board revision i haven't got scans for...
Ok, I'll check all the ones in case there's another one that isn't on the list and I'll start with one of them when I canIF its Not in the list... then i don't have it. So scans of that would be cool
Bugger... Ali returns don't always go well If you need more help let me know. My PGM Discord server is helpful as well.
