obitus1990
Maybe I'm not using the correct set of keywords to bring up results here in the advanced search, but, how do you disassemble a Happ rotary switch joystick to install it into a panel? Unscrewing the set screws on the oversized actuator that serves as the coupler to the rotary switch is easy enough. That allows me to lift the rotary switch out. I cannot figure out how to remove the actuator though, as I do not see any other set screws there which would engage the shaft of the joystick. I am assuming that, under this actuator, there is a D-ring to remove the shaft like on just about every other joystick. How do I remove the actuator/coupler?
Thanks!
Thanks!
