Hello from San Remo Victoria
Goldie05
Australia
I've been looking for a site like this for some time now, I have a Taito table top gallaga, since 1990, which i am trying to fix, the unit turns on ok but seems to hang and not load the program, hoping someone may know the cause, it's only done this in the last 3 months.
Cheers
Goldie05
Hey mate, nice to have another Victorian join.
As far as your issue it may be worth pisting a thread about it but... does it pass the RAM test and then hang or does it do it before that?
Hey Big_P
Good to see Victorians on the site, wasn't sure what to expect.
Thanks for the reply, not sure about the RAM test, I'm a real novice when it comes to the internal workings of the machine, so I'm hoping someone can do a step by step. I put a post on today and see what happens, am I allowed to put a video on to shopw what happens when I turn the unit on ?
Hey Big_P
Hi Big_p
I could have posted the tread in the wrong, I'll try again later, I'm pretty sure it hangs before doing anything like a RAM check, goes straight into the screen attached, do you have any idea what the problem could be ?
Hi Big_p
Start with the basics, verify your +5v is good, check the ROM pins are clean and making good contact, verify the ROM data, check/clean the connectors between the two boards and clean the JAMMA edge. See if that helps.
If not there is a bunch of stuff it could be, but at least you know its not any of the above.
