AlexandreHernan55
Hello everyone, I hope you can guide me on how to assemble this Sega Model 2 motherboard. I have this wiring harness and this board. I've been looking for information, but it's a bit confusing because my CN8 connector and wiring harness indicate that there is voltage, but some sources I found say that CN8 should only transmit data, not voltage. I hope you can help me assemble it correctly. I look forward to your replies. Thank you.
By the way, what is the name of the game on this board? I can't find a label with the name.
I'll upload a picture of everything I have below.
I'm not sure if this goes on the board, but I think it's from another board; could it be a part called a dongle from a Sega Model 3, or does it also work with the Sega Model 2?
This is the part that confuses me: CN8 says there shouldn't be any voltage, but following the wiring of the JAMMA adapter, there is voltage at the 5V pin.
I only managed to connect two connectors: the RGB one and the other, which is the output for the controllers like the buttons and joystick. If I'm not mistaken, I only have two connectors connected. I can also connect the 18-pin CN8 connector, but as I mentioned, it injects voltage there.
This is the CN 18 connector on my motherboard. According to the wiring diagram of my JAMMA adapter, it receives 5V+ and GND. Does it belong to this motherboard or is it from another one?
This connector has 12 pins. On my I/O board, I don't have a connector that matches these pins; the closest one has 10. I understand that this 12-pin connector powers the board. What can I do with it?
This is my JAMMA adapter wiring harness.
My cabling has different connectors, but they don't match the inputs/outputs.
In the following cases, I wasn't allowed to upload more images.
https://prnt.sc/afKrSb_VNzi9
https://prnt.sc/FmTWIW9_RFry
https://prnt.sc/t5rLElr1ens-
your game is Dynamite Deka 2 ?
