RetroRGB
- Joined
- Jul 21, 2015
- Messages
- 40
- Reaction score
- 70
I have two tabletop arcade machines with a 14" CRT built in that both have the same issue: The image won't fill the screen. I recapped one of them and it was zero change. I tried tweaking the POTs and was able to stretch the image wide enough to overscan and while it's not ideal, it won't really take away from gameplay.
The vertical adjustments are still off though; I can stretch it, but can't get it low enough to fill the bottom of the screen. I tried replacing the 5k vertical adjustment POT with a 10k, but it does the exact same thing...one I hit about 5k of resistance, the image stops moving down.
I'd like to at the very least fix the vertical position, but since this CRT is practically brand new, I'd love to get both horizontal and vertical as good as I can. I believe I'd just need to switch out two capacitors with different values to fix this, but I couldn't find any information on this chassis anywhere.
Can anyone here offer suggestions?
Original Geometry - Top is fine, but left, right and bottom aren't fully used:
https://i.imgur.com/kdjlnKn.jpg
https://i.imgur.com/g1cgkh4.jpg
Current Geometry - It's not bad, but there's a LOT of the top cut off, so being able to "lower" it more is the minimum goal for me:
https://i.imgur.com/NpIqKS2.jpg
Chassis, pre-recap: https://i.imgur.com/McWxZys.jpg
Neckboard: https://i.imgur.com/xP4ATBA.jpg
Tube: https://i.imgur.com/Xc0Sj8F.jpg
