J
jassin000
According to the LCD screens display... You are getting a interlaced signal, so changing the 240p/288p to 2x will have no effect.
You'll need to mess with the 480i settings.
This has always been a work around if you can't get AV1 to work, and is why I'm always bitching at you guys asking for the HD15 HATs and adapters...
Unless you have a F3 or other strange sync board YOU DON'T NEED IT and YOU SHOULDN'T USE IT!
It should always be used FIRST, only if you can't get the game working with SCART/AV1 (75ohm sync) should you switch to HD15/AV3 (TTL sync).AV1 via SCART and got both these games to work fine.
That's useable on your HAS as well. It's for the OSSC and using AV3 input for certain systems, such as the Taito F3.
