Home Arcade System
I used interlaced and not interlaced as a test and no effect there. I have a SCART cable that goes to OSSC and then HDMI to my Marantz and my TV. Tried to bypass Marantz and plugged it straight from OSSC with HDMI to my computer screen but no difference.
Is it the same when you use the "unprocessed" CSync mode?
I have my HAS connected with a CPS2 along with a hick harness from HAS. For some reason the 5 and 6 inputs seem to be swapped so it appears like this..
1 2 3
4 6 5
Is there a reason for this? Should i just swap the cables on the harness to fix?
1 2 3
4 6 5
what fightstick are you using?
@Foxhound2153 Try to remap the controls from the HAS. This is from the manual.
Button configuration mode Press and hold down two arbitrary buttons and the START button for 3 or more seconds. After 3 seconds an appropriate status LED on the HASboard will light up and buttons will no longer register – this means the HAS has entered the buttons remapping mode and you can release thebuttons. Right after you release the last of the buttons held down, you can set a new button layout by pressing buttons. Each press of a button corresponds to the JAMMA button number. If you press a button once, it will be JAMMA button 1, twice - button 2, thrice -button 3, it works up to button 6. The seventh press disables the button; the eighth press starts the countdown over. No button press means thebutton will not be set.Additionally, each press of a button is indicated by the status LED blink. To exit the button configuration mode and save your new layout, press the START button.Side note: Every time you access this mode, your previous layout will be erased, and you will need to set your layout anew. This is an easy andfast way to reset your settings.
Hey so I see there have been no updates since I last posted in this thread in May. Just checking if anyone knows the possible status of the HAS? I just purchased my first standard arcade game PCB and would love to be able to play it :)
PM me, I may have an extra full set up for you.
In general he's always said that he does this in his free time as it's not a full business for him. I'm sure he's either working on the current wait list or taking a break given the state of affairs in the world at the moment. I'd love to pick one up too but patience really is a virtue here. Gotta wait for the best products.
I'm trying to connect my HAS through a VGA-5BNC to a JVC DT-V 1710C with an original IF-C01COMG (component/RGB card) but I get a pretty dark screen, well, actually a white line where the top edge of the 16:9 should be but no image (I believe that's normal.) I already changed the Sync to EXT and select the correct slot, in my case 2D. Still gives me NO SYNC and HIGH under it. Maybe I should change something on the HAS to make the JCV happy?
Edit: found the problem, broken cable. I get image now but it looks bended on the top, just like the NeoGeo and PCE. This is a very picky CRT with sync. Also the bottom corners are discolored but after degaussing a few times, nothing changed. The HAS is rock solid though. Oh well, I'll keep testing.
Any thoughts on whether my HAS could be the culprit here?
  • 50hz games (Konami PCB) have a rolling screen on my PVM via RGB
  • 60hz games (Midway PCB) display absolutely fine
Have tried 2 x VGA cables from the HD15 adapter with same results.
Have you tried unprocessed CSync (in both 75R and TTL)? It's a CSync directly from the PCB, not buffered by any IC. If that doesn't work, then I'm afraid the PVM just doesn't like those Konami PCBs.
Which PVM do you have? I'm pretty sure they don't all support 50Hz.
Unsure if my PVM is actually having issues. It's a 2950Q which I haven't not made any changes to aside from (maybe) not playing PCBs on it for a month. 60hz games display flawlessly, but pretty much every other JAMMA board has a picture like sync is messed up. Verified all PCBs work fine on my BVM using a different supergun. Ugh.
I believe this is an issue of the PVM itself, as @RGB said unbuffered with 75ohm sync should work (ie is basically direct from the PCB only with attenuated power levels).
To my knowledge 2590Q is not a multiformat monitor. (hence not supports 50hz) Try plugging another 50hz source and see if it works.
Yeah something seems fishy. Mister plugged in via RGBS is perfect.
It has a 50hz and 60hz setting in the setup menu. I think you may be thinking of 15khz and 31khz?
I was actually referring to 50hz/60hz (didnt know 2950Q had a switch, I have 2530 myself). I guess best bet would be to inject 50hz through mister if you have one and see it works for horizontal and vertical games.
