HDemon
I want X Y screen positioning adjustment
https://cdn.shopify.com/s/files/1/0729/0221/3970/files/OUTLINE.dxf?v=1716155574I want a color plate for mine![]()
Oh snap! Gonna have a little fun with this.
Is this the case with every controller you tried through the USB2DB15 on the HAS 5.0 or just with the 8BitDo controller? I saw your message on the USB2DB15 Discord but it wasn't clear to me if you meant that it wasn't working properly in general, or just with the 8BitDo. They say that the 8BitDo compatibility problems with the USB2DB15 are a known issue.2) USB2DB15 doesn't seem to work unfortunately. It's known to work on previous HAS versions and it works on my Minigun without too much of an issue, but according to the built in button tester, plugging the USB2DB15 results in all buttons being pressed at once. Not sure why, and I've updated it to the latest firmware just to make sure. I notified Raph_Friend on their Discord, but unfortunately they don't have one of the newer ones on hand to test it with, and I'm not sure if this is an isolated issue or not.
Just received my HAS 5.0 a little bit ago and I've been running it through some tests for video output! Looks great going through the Retrotink 5X with fairly minimal work other than messing around with the sync a bit on the scaler. There was a couple things I noted about it.
1) Atomiswave requires you to turn Coin chute emulation on before it completely starts up, otherwise you get coin slot error and a loop.
USB2DB15 isnt well designed first of all .Thank you both for troubleshooting this so fast. I had just ordered a USB2DB15 maybe a week or two ago with the intention of using it with the HAS (once that is back in stock and I can place an order). Looking forward to receiving my USB2DB15, and awaiting the next in-stock notification for the HAS. This community is awesome!
I am aware of Undamned but I saw this open source project (USB2DB15) and thought I’d lend them my support, at least financially. Once I get mine I plan to take a look at the firmware code and see if I can help improve 8BitDo support.USB2DB15 isnt well designed first of all .
imho the best usb to db15 released adapter is the one released by Undamned
