nismopunch
I would also like one if there are any left after the ones spoken for. I don't mind waiting either
Hope everything is ok!
Any differences between this and prior version?All HAS V3.1 units are now assembled.
Meeee tooooo!Damn now I want a 3.1 as well
Hi @RGB, how do you implement your buffered CSync?Just slight differences. After many tests I decided to drop the EL1883 sync separator in favor of ISL59885. This means there is no potentiometer anymore. In its place there is a switch to select "regenerated" or "buffered" CSync (but buffered only via a Schmitt Trigger instead of sync separator like in V3). I also used THT capacitors this time, because the SMD ones in V3 were too painful to solder (lesson learned).
CSync from JAMMA goes to one gate in the 74HC14 and the output goes to another gate to re-invert the signal. It's a simple way to buffer TTL CSync, also serves as a CSync distribution.Hi @RGB, how do you implement your buffered CSync?
Are you using an IC or coupled transistors for the Schmitt trigger?
I'm really interested in simply ways to clean up sync signals...
The version 3.0 HAS does this with an add-on option board... I suspect the 3.1 is the same.Will you also have the RGB to composite/s video as well?
