Home Arcade System
If there are still spots available on the list, I'd be in for:
1x-HAS supergun
1x-Sega Saturn to JAMMA joypad converter
Cheers!
I finally found some time to setup my HAS last night. I tried with a couple of boards, all working flawlessly!
I left the Mega System 32 + "The Game Paradise!" connected for my stream tonight. It's going to be 5am eastern time tho :)
YES :thumbup: I hope I am here. What's this PS2 dapter? For RGB output? Can we order it?
I want it....so what's kind of power suplly I must buy. I am french so I need 220 V compatible.
THX I am on the list since June or July....Maybe a lucky day....one stupid question with PS2 adpter RGB output can we use the lightgun?
@RGB Ok, I need the mini din to vga adapter, plus that ps2 adapter, hook it up brother, need 2 of each please.
Uh... Homie the PS2 adapter is for connecting a PS2 SCART cable.
PS2 RGB Scart adapter:
Don't you have PVM's/BVM's?
If so, I highly recommend you buy only the HD15 adapter for the HAS and use a VGA-to-BNC cable to drive the monitor(s).
Leave the 5th BNC (normally VGA pin #14 ie V-sync) disconnected.
Don't anyone go getting fancy ideas, like for example you are going to go buy a PS2 component cable for use with this.
This is only a connector, it will not convert into the YPrPb component format required (you would need an external device for this).
IT'S ONLY FOR a PS2 SCART cable.
Don't you have PVM's/BVM's?If so, I highly recommend you buy only the HD15 adapter for the HAS and use a VGA-to-BNC cable to drive the monitor(s).
Yeah, thats what I need, never got around to getting those.
