@nonosto - I recommend you buy a Mean Well MWP-606 or SUZO 42PP0606, the best PSU I've tested so far. The metal cage is really sturdy, build quality is top notch and the PSU doesn't get hot.
I will offer or at least release STL files for a cover for the Mean Well MWP-606/SUZO 42PP0606. It will be screwed to the unused COM terminal to hold the cover in place.
PSU connection:
I include the harness that goes between the PSU and HAS, you just need to buy the cable that goes between the PSU and the wall socket. Standard computer PSU cable will do, just cut and strip it. Even better would be an IEC cable with a switch - https://www.atxpowersupplies.com/computer-power-cord-with-switch.php
Avoid cheap Chinese PSUs and power cables.
PSU connection:
. They suggested me the TP-100A as a replacement, but it has 100mV ripple. In other forum I've been recommended the MWP-602 that looks very similar but I can't find if it's obsolete or not.
