How hardy are Triforces?
A multimeter can help verify.
Basically if the negative side is going to ground, you can tie into any other ground point.
recapped it - put it all back together again - no dice... exact same behaviour...
Oh well - it was a long shot - I will keep looking for a Triforce Type 3 system.
Matt
But - let me come back to an earlier question - does it seem like L3 should have something? I think an "L" is an inductor right - which don't have polarity - but this part looks like it was polarized...
At this point, I think that previous repair with the green wire is suspect.
You might be able to source another baseboard, but I guess we have no means of isolating that as the issue. You'd need another working Triforce to swap between.
It might be worth reaching out to ken@irepairsega.com to see if he has any baseboards.
I want you to get a working Triforce Type3 so you're motivated to package up netbooting, card reader script, and Mario Kart camera into one RPi! ;)
already there.... :) I saw the camera code and have the Rpi working with the card reader, etc. for my Chihiro - shouldn't be tough to get the camera added into the pacakge! :)
Ken got back to me - looks like he doesn't sell the boards, but will do a swap - so working with him on the details. Thanks!
Matt
So Ken took a look at the board... it looks like either the whole system got overheated to the point where smd components all slid over a bit or someone used a hotplate to try and do some work and jacked everything up.
He is going to work on assembling some parts for me to get a working triforce3 - but basically I got a case and a fan and a filterboard I can use.... :/
I knew it was gamble - but didn't expect it to be that bad!
That's rough, and probably not indicative of the norm I would think.
If you're ever looking to pick up another, keep an eye on Yahoo Auctions Japan. I've gotten 2 from there for about $200 shipped each and got an as-is broken one for less than $200 shipped from US eBay, and out of the 3 one worked and the other 2 were revived with recapping. I think I got pretty good deals in retrospect, but I'm assuming deals can still be had.
My experience leads me to believe it's potentially worth the gamble on an as-is unknown condition one, though you've unfortunately proven the downside, and there are un-salvageable junk units out there, I guess.
I have a Triforce 3 that doesnt work. No idea why or even if anything about it works but your welcome to any parts. Im guessing the board the cpu is on is bad. The network board was good since i took it for my working triforce so it couldnt have been completely shot.
well i got the other one jjcool was selling. it doesnt boot up on power. got it open led 2 is just flasining red on the bottom board. looks like it is time to call ken.
iirc these use a standard japanese gamecube motherboard, might be worth picking up a cheap gamecube and try swapping the motherboards.
It's not that simple, and the failed boards are not necessarily the GameCube motherboard.
I believe there is some inboard firmware and perhaps hardware differences that keep a stock GC motherboard from be swapped in.
oh that's right, I remember now I swapped one a few years back and had to swap the bios chips over.
