How to fit a Naomi in an Astro city?
darksofter
Hello Everyone,
I have a Astro City with Naomi 1, a compact flash to dimm setup all hooked up to a Capcom I/O powered by a PC PSU. How can I fit the Capcom I/O and the Naomi onto that wooden board and where would I put the PC PSU? Is there a way to wire the PC PSU into the same switch of the Candy Cab?
I would be glad to listen to your suggestions.
This is all the Naomi gear.
I also have a Sega I/O
There were long metal feet that mount the Capcom IO over the Naomi, discussion about them and models for 3D printed reproductions can be found here: https://www.arcade-projects.com/threads/capcom-io-tall-feet.17744/
I have my Naomi and Sega IO mounted side-by-side in my Blast. It's an uncomfortable squeeze with the JAMMA edge facing out, but better with it facing down. Not sure about a Capcom IO or the power supply in an Astro.
https://www.arcade-projects.com/threads/mounting-a-naomi-and-a-cps2-in-a-blast-city.22132/
Yeah you are probably so right.
Why can’t you fit a tri sync monitor into an Astro?
This is really good. I will look into this. Thank you for the help
Little bit of a necro bump but sharing my solution for wedging a Naomi inside an Astro City. My ultimate goal is to get a Net City for the Naomi but, in the meantime, the Naomi sits in the NAC.
Firstly, I went with a power supply that provides the 3.3V necessary for JVS systems including Naomi. @AlxUnderBase recommended the NVS-4000 and it has worked really well for me. An added benefit is that I now have stereo sound in the cabinet.
Next, I opted for a TD-IO rather than a Capcom IO. As mentioned in a post above, you can buy or make your own “tall feet” for the Capcom IO so that it sits above the Naomi motherboard.
That wouldn’t really work for me as the PSU I’m using is much taller than what came in the NAC originally. I also went with the TD-IO since it has a smaller footprint and it doesn’t introduce lag like the IO board from Capcom. An IO board from Sega with a JAMMA edge would also work and would be MUCH cheaper but I didn’t want to mess with modifications to get buttons 4/5/6 to work. The TD-IO has a CPS2-style kick harness connector and that’s much easier for me. Another benefit of the TD-IO is that I can chain the JVS IO for analog controls or players 3 and 4. Here, I’m using the very awesome MultiJVS from @Darksoft and @winteriscoming. This allows me to connect a couple of DB-15 arcade sticks for some 4-player Power Stone action.
Finally, fitting all of this inside of the Astro requires mounting the Naomi vertically and mounting vertically requires inverting one of the Naomi mounting brackets as it’s too long to fit on the Astro PCB mounting board. I had to mount some access holes on the bottom of the mounting board so that I can reach the screws the attach the Naomi to the mounting bracket.
I’m very pleased with how this setup works for me. I’m running WiPi netboot and just leave the Pi resting on top of the PSU. Having said all of that, there are some concessions and drawbacks:
  1. Going with a NVS-4000 PSU is expensive and you lose -5V. That means that this PSU does not follow the JAMMA standard. Again, @AlxUnderBase helped here and suggested adding an in-line fingerboard with a negatron for games that require -5V for audio, (Mortal Kombat for one).
  2. Using a TD-IO in this setup is expensive compared to using a Sega IO or even a Capcom IO. A TD-IO is around $250USD as of this writing but it is open source and you can build one yourself for cheaper.
If you have the tools and are handy, a great alternative is brilliant cashbox shelf mod.
@kikaso
This is very well executed.
What a beautiful job. I have a Sega IO connected to Naomi. I am really interested in the Multijvs for player 3 and 4. Is your NVS 4000 mounted on a bracket. I have mine on top of a brick but I would like to 3D print one.
@kikaso
Thanks!
I purchased the repro metal bracket for the PSU from @Battlesmurf
@ItsBobDudes released a really neat design for mounting the NVS-4000.
