Info Request: Building a Dedicated Mahjong Harness for PANA TWIN MP-92
ElQuijote7
USA
Hey everyone,
I’m in the process of building a fully dedicated Mahjong harness for a PANA TWIN M-92.
Can anyone confirm the Mahjong portion uses a JST XH connector (2.5mm pitch) with 11 pins?
If you happen to have one of these setups or can share any detailed pictures of your harness, diagrams, or pinout references, it would be incredibly helpful for the build. The more detail, the better!
Really appreciate any help you can provide—thanks in advance!
P.S. I did checked Arcade Otaku, but the image for the dedicated harness is blurry. The JTS says 11 pins, but it does not give me the pitch. I used my calipers to measure the pins on the Pana and arrived at 2.5mm pitch, just want to confirm. 👍
Hey there - I unfortunately don't have any info to share, but I am in the same situation. I have a PANA TWIN M-92 and Idol Mahjong Final Romance 2 board that I'll be working out how to connect. I'm still a few days away from having the equipment on hand, but once I tackle this I'll share everything I learn in this thread.
Sort of a side note just incase it helps out. I am terrible with Jong configurations and have no idea to the answer of the original question. I did however build one of buffis mahjong adapters and a Mahjong keyboard for personal use. As the MOQ on the pcbs was 5 I still have 3 left if this helps anyone out at all. This definitely uses JST XH and there are 11 pins (+ an additional 4 for coin service etc)
