Jambo Safari Upright to Crazy Taxi Upright (and making my own CTHR Shifter)
Hopefully / maybe? I'm unfortunately struggling to find where I had the actual wiring diagrams. However...
Open up your cp. Hopefully it's basically the same as my CT. The top left and center connectors are the shifter/view change/etc connectors. The one that goes to the shifter is basically just flip-flopped between the original Crazy Taxi standard and basically all other Naomi/Chihiro drivers.
(see in my Pic where the white plug is in the yellow socket? Basically I swapped that one, and did a dirty rig of pins in the other socket as I didn't have a spare male connector housing)
Crazy Taxi has a debug menu, which you can access with inputs that aren't normally used. Those will trigger when playing on a Jambo Safari cab.
Crazy Taxi debug controls:
https://www.arcade-projects.com/threads/crazy-taxi-sega-naomi-pause-button.7190/#post-111510
Crazy Taxi and Jambo Safari shifter pinouts:
https://www.arcade-projects.com/thr...mbo-safari-gti-club-2.6133/page-2#post-314637
I would just install a DPDT switch if I was swapping the two games often.
EDIT: note that I haven't actually verified the CT shifter pinout. The one in the schematic seems to clash with the pic above?
