Jasen's Customs: Panzer Fight Stick 4
JasenHicks
Northern Virginia, USA
The Panzer Fight Stick 4 is coming. I’ve teased a few pictures in Discord and Twitter and not so subtle hints as to what it’s all about, but that changes now. Keep an open mind and read all the way through!
The PFS4 is going to be a swappable panel fight stick. Not like the Panzer Fight Stick 2.0 (circa 2015) that had the flush panel that bolted down into the case as it was quite pricey to produce but more like the Madcatz TE where it sat down on top of a base frame. This will simplify the build and keep costs down while also letting me mix metals to keep the weight of the stick in check. One of the common “complaints” of the PFS3 was it was heavy, and folks didn’t like carrying it around to tourneys. Some other metal fight sticks account for this by using thinner metal but some have told me that the thinner metal doesn’t feel premium. I am going to use aluminum as the chassis material and the swappable panels will be cold rolled steel like the PFS3. This should add just enough weight to help keep it not feel like a toy or move around during play.
For the swappable panels, I thought about this for months and wanted to think of the best way to have quality panels that would help keep pricing as low as possible. Then it hit me! The Madcatz TE panels are perfect – by designing the PFS4 chassis to support them it helps two major segments of the community and allows economies of scale to come into play. Additionally, it really makes a number of layouts viable because more than one segment will use the panels; making minimum quantities isn’t going to be a problem.
What about the hole in the panel for the aux area of the TE? That actually benefits the PFS4 a lot. Wiring 6 extra buttons, using LEDs, and such wasn’t hard on the PFS3 but on other frames requires extra wiring and that can be tedious to get looking great. The Panzer 4 has a custom aux PCB that has one plug and play wire loom connecting it to the various points on common Brook Fighting Boards (UFB/PS4+/PS4 with Audio) and other boards in development. Access to the buttons on the aux button will be done via machined aluminum caps and LEDs for Player and Turbo indicators will shine through light pipes. These caps will add cost to the Panzer but having long stem momentary switches poking up through the case would detract from the premium build of the PFS4. This approach will save time and cost of sanwa/seimitsu 24mm buttons ($15.75 for 7x 24mm buttons).
Is there an EZ BUILD like the PFS2.0 and 3? Not in the traditional sense. Having the PCB under the panels created complexity with offering new panels. Each new panel required a new PCB and the testing and manufacturing that went along with it. Ultimately, this would create R&D costs that would be passed on to you. Less popular panels wouldn’t be feasible under that model. Instead, I created a PCB that snaps onto the standard PCB outline making use of the 20 pin header and the included wiring harness makes connecting the buttons and lever a breeze. This entire combination of EZ WIRING should be on point with the 20 pin wiring harnesses most shops offer.
Plexi overlays won’t come standard with the Panzer 4 – but you can order them and add artwork with it. I will be doing printed plexi runs (I've been doing these for a few years, some shops call them underprint plexi) each month to support the new builds. Paper Art + Plexi is about $30 total – a printed plexi is a bit more but the quality is much better.
I'll post more updates here, likely a few days after the Discord updates. A lot of prototype parts are underway and headed to me. I think most arrive just after graduation and in time for the holiday slow downs in my office!
The Panzer 4 / Madcatz TE Panels dropped today! A lot of good layouts that will go great on both the Panzer 4 and your Madcatz TE restoration/rehab projects. I intend on having a special this weekend for free shipping worldwide, but if you want to support and don't mind paying reasonable shipping go ahead an order now :)
https://jasenscustomsarchive.com/product-category/fight-stick-panels/
It's official. I'm back in the #FightStick game. The #PaznerFightStick4 #PFS4 chassis kit just dropped and panels have been available for about a month. First run colors may not make a return, so don't sleep on this if you want one with the various color options.
Link: https://jasenscustomsarchive.com/product/panzer-fight-stick-4-chassis-2/
Shown are just some of the options that you have with the Panzer 4. Printed Plexi artwork or not. Swappable Panels with the layout you prefer. A tidy area with all the auxiliary functions and indications for your Panzer, and a machined aluminum bezel.
If you had reached out, sent me pictures, and shipped the damaged or defective product back I would have refunded it. Since absolutely none of this rings a bell, whatsoever, and is clearly uncharacteristic of any of my customer service practices - it’s a pretty strange post in general. Interestingly, I have no recent dms on discord about any fight sticks I’ve sold recently.
Thanks for posting this though?
Ok, thank you for your feedback. By the way, what was the order number(s) and when did you revive the panzer 4 and panzer 5 with Hall effect board? I’d like to look into this further.
I’m not engaging with you on this on a forum. If you’re being honest you can email me via my website with your order number and I’ll review the details and look for previous exchanges. In your email, please include your discord handle so
I can review those messages as well.
I’ve reported all of these notes to the admins here. As this all seems very strange given some other non forum interactions of late.
Hey I purchased one of these Panzer 4 Fight Stick and am leaving my review.
Packing: Was shipped in a plain sturdy cardboard box with ample protection for the item
Components: Shipped with screws that do fit and an extra pcb depending on setup
Quality: Amazing quality build, seriously it's a tank, flawless and beautiful
Support: Excellent support in a timely manner. My custom reverse printed plexi was incorrect. Jasen resolved it and sent me two in different gradients for FREE.
Follow Up Support: Went to Discord and bought some of Jasen's odds and ends, chit chatted with him and some other decent people along the way
Conclusion: Highly recommended, stay and play!
