digitron
Probably RT5Xsounds fun, what are using to downscale ?
Rough draft maybe = PS5 > HDMI to VGA Transcoder > (Extron RGB Interface, DDSP ON) > RT5X Scart > RT5X HDMI Out > HDMI to VGA TranscoderHdmi to vga then vga to vga ?
Same but I still have a CRT Emu Driver setupI now buy all the games (that play nice on a CRT) on steam as its very easy to get a nice 240p/480i image to the cab (through a PC with Batocera 15khz script). Console downscaling gets too complicated and cumbersome very quickly.
Mame and steam in any res between 15khz and 31khz works amazing. For console stuff, the only thing I am missing mainly is Cave releases that are not on steam, you can emulate PS4 releases and Xbox360 releases to supplement. PS4 you can also throw CRT Beam Simulator on top on a modern display. 360 stuff should work on a CRT but I doubt PS4 would.that project looks neat but the main utility of this to use modern PCs with JAMMA cabs. That involves Calamity's CRT Emu drivers to output 15khz video from the PC (often a specific and supported video card). and some kind of I/O device to send controls to a JAMMA loom. I don't think that's your project's aim, is it?Realise im really late to the party on this one, but did you see this project i launched a couple of weeks back?
Supports a bunch of cabinets with no hardware mods needed
Hi people,
It's my first time posting here. Some of you may know my from my work on Teknoparrot FFBArcadePlugin, outputblaster and FFBBlaster.
In the background over the past couple years I've been building a project called Arcade IO Emulator for myself really.
It means I can leave all my original hardware in my arcade cabs, but swap in a modern pc if I fancy with no wire cutting or hardware mods.
Just connect cables to pc and away you go.
I wrote this around raw thrills cabs originally, it's what I have personally and it works flawlessly allowing controls, outputs and ffb to work as...
Feel free to disregard my previous post, sorry!!Can you make JVS to be recognized as XBO360 controller ? That why capcom IO could be used to connect to PC (to JAMMA) for both controls and video. If you do that then I guess may be reach out to Batocera Team and see if the driver could be included in their build as currently Batocera is the easiest way to get 15khz out of PCs.Realise im really late to the party on this one, but did you see this project i launched a couple of weeks back?
Hi people,
which pc to JAMMA converter have you landed on as the "best" one? I recently ordered one of the SQ arcade ones from Aliexpress but its gonna take months for it to arrive, and unsure if it's even better than the antonio villena ones which i can get a lot easier. Really looking for a nearly lag-free experience here as some of the converters ive seen add 2-4 frames of extra lag which is unacceptable for me :')3rd Strike decomp working great on Batocera 15khz, that arranged CD quality sound track is fire!
Thanks a lot for the pics! I'm now wondering if the db15 switcher is what causes the dimming, or does the SQ Arcade do it even direct connection? Also the SQ Arcade you have (with the 2 rpis in the bottom) is different from the one i ordered which was linked in a GraveCade video, maybe the SQ arcade peeps can chime in @FunFortress Retro Game what is the difference between them? I'd like to find one with little to nodimming and least amount of input lagThis is how the PC, Sega Saturn console and Mister together with DB15 and Audio switch boxes sit in the arcade cab:
This is Capcom IO board
and this how the DB15 adapters are made to use with JAMMA inputs and GP2040-CE board
Yes SQ arcade would work fine, you might have to crank up the contrast knob abit and have to adjust back and forth when you switch between PC and arcade PCBs
