zedmekis
Canada
Hi,
I have a Lindbergh with a multikit,
all the game are mounting one after the other. After that the cab restart and mount all the game again and so on.
I'm wondering where is the problem ?
thanks in advance
UPDATE: I finally was able to pass the problem... to fell into another one now when I start the game I want I have the message :
EXT2-fs warning : mounting unchecked fs, running e2fsck is recommended
then it come back to the menu to chose a game
I would say your
Hard drive has become corrupted
You can try clone the hd onto a new good workin drive .
Use a hd cloning program like
Sounds like damaged sectors. You would need a new HDD or SSD depending on what you used for the multi.
Be aware, there's a chance you may not be able to clone the drive if there are a lot of corrupted sectors which impact the data heavily.
But, if it does copy over, then the corruption wasn't bad.
