Low Voltage Atari Millipede Arcade Machine
Rick Gadz
United States
I have a Millipede Arcade game that has been converted to also play Centipede. I've owned for years and it has been working great until now. When powered up the monitor has a "garbage" screen, which I believe means that it is stuck in Watchdog Mode. There is continuous beeping. I am only seeing about 4 volts at the PCB and AR-II Board.
With the PCB disconnected, I am seeing around 5 volts. I can adjust the Pot and the voltage varies from about 4.9 volts to 5.9 volts. When I plug the PCB back in, the voltage drops back down to about 4 volts.
I cleaned the PCB connectors and Pins on the board with a fiberglass brush and spraying with Deoxit contact cleaner. Unfortunately this did not fix my problem.
Any advice on what I should check next? Should I be looking at or checking the LM305 regulator chip or the 2N3055 transistor on the AR-II board? Thanks in advance for any help with this issue.
UPDATE - I replaced the 2N3055 Transistor and the machine seems to be repaired. I've had the machine powered up and playing on it for over an hour and all is good. Thanks again AeroCity20XX for your assistance, much appreciated!
