Mini Cute Arcade Cabinet
Let me tell you... I’d order one.
Really? Why?
I can understand the Mini Cute repro, because people don't want to give those up even for massive amounts of money. However, Net Cities are pretty abundant and, dare I say it, affordable. It's not like shipping a repro would be any cheaper than a real cab.
Shipping a fully assembled cabinet to Costa Rica is effin’ expensive... 57,61% in customs taxes. Actually, anything related to video games, pays that amount.
However, if the repro comes in a crate as a “assemble it yourself” kit, the space required in a container will be lower, reducing the shipping costs. Also, a lot of metallic pieces with no form or whatsoever will be tagged as “spare parts” and the customs taxes will go down to only 13%.
I understand what do you mean. We have the same situation in my country. Even we cannot import any thing which used item. Used items are forbidden to pickup from custom :) ( F...king rules ) :P
But im really sorry , mini cute is 2 part. Maind body and the Door. All the other parts are welding together
The production is going fast nowadays.
İ talked with some company to make a mold for the Radus corner.
They already started to produce it.
This is the technical pictures of the mold.
"if the WG K7000 19" monitor can be find in USA easily , I can make it for it. But I will need some measurements for the monitor :wink:"
Guys, get this man the WG K7000 19" measurements if you have one. Thanks
Yes please
Hey people
I still need WG K7000 19" detailed measurements....
Hey people
I see a few on eBay.. can you tell me what exact measurements do you need and I will message the seller asking for those measurements..please be clear on what you need and the line of questioning.. thanks
Please check the pictures.
1- I need the measurements of the holes sizes and distance between them. Left to right and up to down. You will see the red lines
2- Total measurements of the monitor, from Tube to chasis end point.
Why would you want to take the tube out of the frame?
Tube looks like a regular A48? I can take those measurements. However, I really think you should use the four oval holes on the corners of the frame for mounting.
Ok.. I will ping those sellers.. I also, reached out to a local Arcade distributor to see if he has one for sale just in case the eBay seller does not reply or something.
Edit
Here is the reply.. let me know if you have any other questions, this seller replies fast.
Left to right 17” center to center. Up and down is 13 1/4 c to c and the total depth is 17”
Instead of aiming at fitting a WG k7000. 19" monitor is there a way to work on fitting any 19" arcade monitor with a standard frame like what @nem sugges@'nem'?
Another measurement from @Silly_B
I have 17.25" width center to center, 13.25" height and 16.5" depth, to the edge - but the curvature of the screen in the center would make it 17" most likely.
Thank you for the info.
NP, just let me know which ones via a drawing. It's just gathering dust in the garage.
