Exactly this, though I'm using a 4 channel digital potentiometer. This is controlled via a custom SPI class I wrote in Arduino via an Atmega328 and visually displayed on an OLED screen.
That is not an on/off switch for the minigun. That is an on/off switch for the Low Pass Filter (LPF) of the video buffer chip. The minigun doesn't have an on/off switch. If you want an on/off switch you should add it to the power cord for your arcade power supply.Currently my Supergun is turning on without the switch turned to 'on'
I use the minigun connected to my gscartsw and then from there to my framemeister. I use this cable from my minigun to my gscartswFinally got around to building my first minigun it was really easy to solder for a noob![]()
I have been reading up on different the types of SYNC but still confused on what is safe to use on my Framemeister XRGB Mini i built the mini din 9 version as i already had a spare cable on hand.
Do i have the correct cable and what should i set the jumper to 75ohm or TTL ?
