K0NAM1
Yes, the DIN connector on the minigun carries sound.
What arcade board are you using, some of them need -5v (minus 5v) also?Hey all
I noticed that for Version 2.5. It has 2 terminals for +5V. The Atx breakout board I've order only has 1 +5V connection point. If I just connected one of them, would it be ok?
I've tested the following:What arcade board are you using, some of them need -5v (minus 5v) also?Hey all
Gotcha, CPS2 definitely doesn't need -5v and Denjin Makai II looks like it doesn't need it either, all my old Konami boards need it.I've tested the following:What arcade board are you using, some of them need -5v (minus 5v) also?Hey all
Denjin Makai II
CPS2 with Aliens vs Predator and Super Street Fighter II turbo.
I believe he posts here yeah. Anyone named Evilsim?@klee123 all good, did you get it from ebay or someone on here?
I had no audio on the minigun because I decided to leave out the audio jack, the audio jack has a switch in it so even if you don't use the jack you need it to get audio out of the DIN. If you bought yours assembled then it's not that lol, I use an OSSC so I can't help with the framemeister, it might be a component or soldering issue.
I've recently ordered just a standard multimeter which I will use to check for fault finding.It depends on your knowledge level but a logic probe is a pretty cheap and easy to use troubleshooting tool:
https://www.amazon.com.au/Elenco-LP900-625-Logic-Pulser/dp/B0002E7X5O
You basically connect it to your PSU 5v and when you touch a pin or PCB contact you can hear the logic, or the audio.
What I've done as a quick fix is to order a headphone to RCA stereo cable as a stopgap solution.I used @Frank_fjs DIN to SCART PCB and an off the shelf DIN cable, works great.
Hey mate, it's all good, I did make the unusual request for the RGB plug to be wired to JP-21 spec after all. That said, the picture quality is awesome.Yea hello did I mess up the pinout on your jp21 ? I copied some diagram from google but could have made a booboo I guess.
Have you tested audio from the cps2 rca jack ? Maybe the volume on the A board is very low ? Hit me up if I can help but lots of people here know lots more than me![]()
Hmm, I'll keep that in mind as well. Might just try to get some cheap RCA stereo cables then.Ok cool,.cps2 is far better in stere-ere-o!
Cheers hope you enjoy playing
The supergun doesn't produce a signal that will work with your consumer TV or your VGA monitor. You will need some sort of converter.Hey, I'm pretty new to the supergun area. I bought a minigun v2.5 already assembled to use with some arcade boards that I own, outside of a cabinet. I want the display to go to either a consumer TV
or I have several old monitors like this https://www.cnet.com/products/envision-en710e-crt-monitor-17/. I understand the pinout for the 8 pin mini din, but this is where I get stuck. I have 8 pin mini din connectors. If I were to make a cable with component RCA outs to the TV could that be done without any additional circuit? I do have a GBS 8200 V4.0 so maybe that is the best way. Connect the RGB to match to pins 876, respectively. Then match pin 4 to the ground on the 8200 and pin 3 (sync) to either the H-sync or V-sync on the GBS 8200. I would not connect +5v pin 5 from the mini din since I will not be using SCART. I would not wire the sound through the video cable so leave 1 and 2 unconnected. I might prefer to wire up the RCA cables for the TV if that works, but if not, the GBS would be OK. Do you think I am heading down the right path and do you have any advice? Thanks!
