Raph_friend
That's a really good and cheap option.I plan on using a bunch of these but have not soldered them up yet:
https://github.com/MickGyver/DaemonBite-Arcade-Encoder
Are you planning on selling a few completed? I would like 4 if you do.I plan on using a bunch of these but have not soldered them up yet:
My plan was to design a 3D printed enclosure with a jamma edge and these inside but am still waiting on parts to start working on this. Might take a while until I make some progress there.Are you planning on selling a few completed? I would like 4 if you do.I plan on using a bunch of these but have not soldered them up yet:
For vewlix owners, maybe @Arthrimus can whip up something that attaches to his vewlix console IO boardI plan on using a bunch of these but have not soldered them up yet:
Thanks for the linkI use this to play MiSTer on the New Astro City.
You need to look into that..the last time I checked, that jamma device only works with his MiSTer or cores or some shenanigans like that..someone correct me if I am wrong.Thanks for the linkI use this to play MiSTer on the New Astro City.
Those look very nice I would pick one up if available.
Oh, I see how Antonio is doing to work around the 2player issue with one usb device.
He is using these boards XM-10 and this is the patch to use on the mister linux kernel.
I wonder what would be the lag using the MisTer with a properly implement fix for the JVS-PAC2 on a JVS cab. There seems to be a lot of talk about controller lag on the mister depending on what you are using.
Ill be looking and checking, just trying to piece stuff together, my MisTer kits should be arriving soon. In the meantime finishing up some other projects while I wait for more parts, etc...You need to look into that..the last time I checked, that jamma device only works with his MiSTer or cores or some shenanigans like that..someone correct me if I am wrong.Thanks for the linkI use this to play MiSTer on the New Astro City.Those look very nice I would pick one up if available.
It works with any MiSTer now. It has been changed.You need to look into that..the last time I checked, that jamma device only works with his MiSTer or cores or some shenanigans like that..someone correct me if I am wrong.Thanks for the linkI use this to play MiSTer on the New Astro City.Those look very nice I would pick one up if available.
Thanks for trying!Tried the J-PAC hack, and mister crashed(!?!). Tried to build the actual Mister menu/input system, but it's not really documented how to do it, and the provided docker image doesn't work (for me).
Back in the box..
https://github.com/misterkun-io/Toolchain_MiSTerI am not sure what you mean by trying "to build the actual Mister menu/input system".
@gusmoney Can you test this out? I just got a mister setup in, need to put it together and figure out what I will do for controls. Ideally this want meant for the vewlix and I wanted to use a JVSPAC2 so I would just hook it to the jvs IO and not have to deal with other stuff.https://github.com/misterkun-io/Toolchain_MiSTerI am not sure what you mean by trying "to build the actual Mister menu/input system".![]()
If you use the J-PAC, can you do a little test? Enter the SF2CE test meny for inputs, and press button 1, 2, 3 etc while keeping them pressed so in the end you should end up with all 12 buttons pressed. Unlike in MAME, I got 'ghosting' and other oddities with Mister.
Please contact me. We are looking for a K007121 chip for opening and reverse engineering.
As mentioned, I don't use a jpac, @Derick2k. Did you want me to do the test on my setup?@gusmoney Can you test this out? I just got a mister setup in, need to put it together and figure out what I will do for controls. Ideally this want meant for the vewlix and I wanted to use a JVSPAC2 so I would just hook it to the jvs IO and not have to deal with other stuff.https://github.com/misterkun-io/Toolchain_MiSTerI am not sure what you mean by trying "to build the actual Mister menu/input system".If you use the J-PAC, can you do a little test? Enter the SF2CE test meny for inputs, and press button 1, 2, 3 etc while keeping them pressed so in the end you should end up with all 12 buttons pressed. Unlike in MAME, I got 'ghosting' and other oddities with Mister.
Crap forgot you use Antonio's jamma adapter. Looked over his site and he says he was able to get it working thanks to Alan Steremberg making a patch. Need to dig a little deeper, maybe Alan can help shed some light on these control issues, and maybe help out with getting the JVSPAC2 working with the MisterAs mentioned, I don't use a jpac, @Derick2k. Did you want me to do the test on my setup?@gusmoney Can you test this out? I just got a mister setup in, need to put it together and figure out what I will do for controls. Ideally this want meant for the vewlix and I wanted to use a JVSPAC2 so I would just hook it to the jvs IO and not have to deal with other stuff.https://github.com/misterkun-io/Toolchain_MiSTerI am not sure what you mean by trying "to build the actual Mister menu/input system".If you use the J-PAC, can you do a little test? Enter the SF2CE test meny for inputs, and press button 1, 2, 3 etc while keeping them pressed so in the end you should end up with all 12 buttons pressed. Unlike in MAME, I got 'ghosting' and other oddities with Mister.
