MiSTer FPGA
A recent update_all broke the Neo-Geo core on my setup. Using the original BIOS gives a Z80 Error, and using the UNIBIOS leads to the monitor test when trying to load a ROM.
It sounds like your core download is corrupt. Load the SD card up on a computer, browse to the _Arcades/cores folder, and delete the Neo Geo entries. Then load the SD card back up in your MiSTer and run update_all again.
I got another SD card and created a whole new MiSTer setup on it, and the problem is still there. All the cores work except the Neo-Geo core.
Edit: Fixed now. Using .neo files instead of Darksoft ROMs worked.
To use Darksoft , you need to do some modifications ... is related here :
Darksoft files were working before. I didn't change anything in the Neo-Geo folder, and that .xml file was present, so it's a MiSTery what went wrong. Using .neo exclusively now.
