MiSTercade V2
Hi guys, I am having an issue getting any sort of display on my Mistervade v2. I'm not using it in a traditional crt cab; I'm using it on the Unico Nova blast. I know the monitor can do 15khz because Midway boards work on it, but I've tried all the ini files, and none seem to work. I have switched the switches, so I have no idea what the default config is now. looking for any assistance, thanks!
EDIT: Turns out the issue was my SD card, using cheap media in MISTer is a nono, make sure you use quality SD cards as it could give you issues you'd never think to check.
I ordered a V2 from the latest batch as well as a Versus. Among other things, one goal I have is that I'd like to be able to use my two side by side 4 slot Neo Geo MVS cabs for some 4 player Konami beat em ups.
So, trying to learn what I'll need to be setting up and doing when it arrives, in the meantime, I have one question. I already have a JNX Big Red converter for the JAMMA to MVS pinout that I can use for the mistercade itself. Do I need a second one to use on the Versus edge as well?
I’m not sure why you would need a converter for the layout as you can remap the keys on mister to whatever you want them to be, but you would need two mister cases and the versus kit which is an hdmi cable (I think) and that should be it as for setting up the versus kit I’d have to let T someone else answer as I have no experience. You can always message the owner on the website he’s very active helping out.
Sorry, it isn't for mapping the button layout. The MVS uses a slightly different wiring pinout on the JAMMA edge. The speakers are wired in series rather than in parallel and the adapter is to prevent damage to standard JAMMA audio amps. That's about the extent of what I know though, so looking for information if anyone else has put either of these into an MVS cab (specifically the US Big Red).
I see the MiSTercade V2 current batch of boards have been shipped, can't wait! :thumbup:
This one will be going in my Pony III as a dedicated vertical shmup setup (Currently have a different MiSTer solution it but not fond of it at all)
Hello all, I have a Mister setup for my Candy cab using the Jamma converter from Antonio Vilena. I got in on the newest drop of Mistecade v2s and want to know if i can just duplicate the SD card i am using into the Mistercade. Also if anyone has a good ini file for a Blast City that would be super helpful. Thanks in advance!
Have the issues with the V2 been sorted now? Seen a few posts on this thread about colour bleeding/fuzziness? Cheers
100 percent sorted out, I can vouch for this. This is a picture of the v2 running on my NAC
MiSTercade V1, meet MiSTercade V2.
Absolutely delighted with this, assembly was quite a bit easier than the V1 with the mounting plates to get everything lined up.
Then just popped the .INI on from Github (replacing the old one I had on) and it fired right up.
As dead silent as the V1.
Hi guys, is this compatible with the QMTECH Mister FPGA?
Thank you all.
The SNK cabinet on the right in my photo has a DE10 and the Pony on the left has a MiSTerPI.
The MiSTerPi just needs a USB A to Micro USB cable to replace the USB bridge board but other than that, it's all the same installation wise.
