I also had some issues with a MK2 board recently.
Sound worked, but after a few minutes of play the sound dropped and the LED on the sound board turned OFF, after a power cycle everything worked fine.
Send it out to my repair guy the board turned out to have multiple issues or things that could cause issues:
- Power cable re-crimped and fixed for some loose contacts on it
- 1 Sound rom was bad, so he burned a new rom and replaced it
- Sound caps where also not all 100%, so these are changed as a precaution.
So if you have the possibility to test or roms or have them tested, that would be a good start I would say
