DARKSOFT Multi JVS v1.0
Weird question but is there any way to switch profiles on the Multi JVS without using the MENU button? I've got one installed in a New Net City, but it sits behind the bezel so it's a little cumbersome to access.
A button combination (i.e. P1 BUTTON 1 + P1 START) for this would be nice.
There is no built-in function for that but you COULD solder to wires to the multijvs and run them somewhere attached to a push button or something. It wasn't meant to be done but it could be done.
Looks like you never got a reply to this. This is addressed in the latest firmware and profiles. There's one called NEOG that should correctly map the ports.
Hey I'm trying to configure a MultiJVS board in a 2L12B cabinet setup with Undamned USB converters. I want to configure it so that people are able to hotswap between using the cabinet buttons and using USB controllers. The default (DFLT) profile has incorrect mappings for USB controllers. The "NEOG" profile fixes USB controller mapping, but it also changes the mapping for the cabinet buttons. Is there any way to set a profile where the onboard controls and UD converter controls match? Possibly with a firmware update?
Yes I have. Making a new profile doesn't fix anything because the buttons don't match up between the cabinet and a controller. 2K is on select and 3K is on Circle (PlayStation) for instance.
My Multi JVS has been working great, then at some point, the screen stopped lighting up and it no longer recognized although the power lights are on and it seems "fine", other than the screen. Any idea what the issue may be? A fuse or something? Anything I can try and see if I can get it back working? Thanks.
Not working at all, in terms of it being recognized - “JVS board not connected…” The lights are on as normal as far as I can tell, no screen and not recognized by the board.
