dillingerradio
Hey folks! I'm hoping one or more of you out there might be familiar with the NeoBiosMasta mod; or, more broadly, unibios installation on an MV-1C board.
I'm attempting to give it a go here, and I'm afraid I've run into a bit of a wall. I'll start at the beginning:
I'm afraid that I lack the knowledge or experience necessary to move beyond this point (outside busting out some o-scope probes to start checking things; but, I'd be poking around in the dark, admittedly). As far as I can tell, this is a successful- if messy- install of the Unibios, and I'm unsure as to why I'm being met with this messy boot.
Any help or direction is greatly appreciated.
Cheers!
- I utilized a heat gun to safely and easily pull the surface-mounted BIOS from the board.
- I placed NeoBiosMasta shroud over the chip as instructed, and attempted to solder CE/OE to pads 10/12 respectively. A mistake ultimately resulted in the loss of the appropriate pads.
- I rerouted the wires according to information I found: CE -> GA1(7), and OE -> GA1(9)
- I tested continuity with original pads and checked for shorting. Continuity checks returned good, the reroute is technically successful; no shorts were detected.
- I removed the BIOS chip from the NeoBiosMasta and verified the data onboard was good, before replacing it and attempting a boot.
Cheers!
