KOarcade
Hi Everyone,
I own a MVS-1C motherboard that has recently started reset looping on the "garbage green square block screen". However, it is only happening with Garou: Mark of the Wolves (Original Cart). I have tested this board on two different superguns with the same game that have sufficient PSUs and have ONLY experienced the issue on the MVS-1C. I will now list below all of my current tests and evaluations. This cart was previously working fine and has been played for over 80+ hours.
Motherboard Modifications: Stereo Audio Mod
Bios: Asian/S3 Ver.6
Supergun#1 and #2 - MVS-1C Motherboard
Other Carts Tested:
Result#1: Garou: Mark of the Wolves (Original Cart) - Cart reset looping on the "garbage green square block screen"
Supergun #1 and #2 - MVS-1F Motherboard (Fully working motherboard, no unknown issues)
Other Carts Tested:
Result#2: WORKS and BOOTS FINE! Garou: Mark of the Wolves (Original Cart)
Would appreciate any input or suggestions regarding my MVS-1C and Garou resetting issue. Clearly the Garou cart is fine since it boots and play correctly on the MVS-1F. I don't understand why it would begin the reset loop? Normally this is due to low 5V and adjustments are suggested. It truly makes no sense.
I get it, that arcade hardware needs patience and I have patience and time to clean. But I feel like I have performed everything that I am aware and researched. I have read replacing RAM chips might help, however, I don't think I need to do this considering the MVS-1C "Working RAM Test" is fine (no errors). MVS-1F on both superguns performed correctly even with Garou.
ONLY the MVS-1C has a reset loop on the green garbage screen with Garou. I have double checked MVS-1C cartridge slot and pins look okay and are making contact correctly.
I do see an area under the cartridge slot solder side that may have some traces that are scratched. However, I have checked continuity and from the points of reference through the traces to the chip legs and these all checked out fine. I have plans to use a magnifying glass to TRIPLE check these traces.
So lastly, do older games use less processing power from the motherboards than newer games like Garou or KOF99/2000/2002?
Scratched traces left of A1 listed on board. I have tested these points. However, I may get positive on continuity if they all meet at ONE point then branch out to their respected chip legs.
Thanks,
- Cleaned Jamma edge on MVS-1C
- Cleaned Cartridge slot on MVS-1C
- Cleaned Contacts of Cart - Garou: Mark of the Wolves (Original Cart)
- Fully IPA the entire motherboard top and bottom sides
- Working RAM Test - Several minutes to several hours. Tests fine
- Tested 5V while powering game measuring from JAMMA edge connector - 4.98V-5.02V (I have dialed this in directly on 5V exactly)
- Tested 12V while powering game measuring from JAMMA edge connector - 11.89V-11.95V (I have dialed this in directly on 5V exactly)
Other Carts Tested:
- Neo Turf Masters (Original Cart) - Tested works fine (even left is running for 7 hours) NO ISSUES
- Darksoft MVS Multicart - Tested, boots fine, loads games correctly and play fine. (Had to make adjustments on 5V but overall worked completely fine) NO ISSUES
- World Heroes 2 (Original Cart) - Tested, boots fine, loads games correctly and play fine. NO ISSUES
- Cleaned Jamma edge on MVS-1F
- Tested 5V while powering game measuring from JAMMA edge connector - 5.03V
- Tested 12V while powering game measuring from JAMMA edge connector - 11.85V
Other Carts Tested:
- Darksoft MVS Multicart - Tested works fine
- World Heroes 2 (Original Cart) - Tested works fine
- Garou: Mark of the Wolves (Original Cart) <<<<WORKS FINE>>>>
Thanks,
