This is almost 100% a bad solder joint or two somewhere. I doubt the monitor was really mishandled but in my/
@aperturegrillz's experience on maybe 100 of these it's very common to run into this issue and it would not surprise me to see it pop up after being moved. Is this an MS8 or MS9? Both are pretty commonly found in NACs as operators never seemed to really care about downgrading them to MS8s; if you let me know which it is I can give you some points to look at that are likely to be the cause. The shutdown / not powering up for a while thing is a built in protection to stop the monitor chassis from blowing itself up spectacularly under certain modes of failure (locked transistors, no horizontal deflection etc), so don't worry too much about that happening as it will go away when the underlying cause is solved.
