mbg
I would like to be added to the list as well!
Sup man I checked out your stream and it was really cool with you running original hardware.I was a able to get an image from the GBS to a monitor directlyLet's find where in the chain there is an issue - do you get an image from the GBS-8220 when plugged into a monitor directly? Furthermore, is this with GBS-control, or the stock firmware? The GBS-8xxx series is not known for great compatibility or performance when stock, so it would be good to determine if that is working correctly first.
Second, does your capture device not accept 15KHz RGB directly? If you have not tried, it might be worth giving it a shot.
This was done with stock firmware, and has been working for me for a while now.
Here is how it looked on stream before hand with the stock GBS-8220
( http://www.twitch.tv/dabsandcabs/v/687079659?sr=a&t=1s )
I am also using this capture device
(https://www.amazon.com/dp/B00PC5HUA6/ref=cm_sw_r_cp_apa_i_krngFbGSZ4APX )
oh snap, thanks man!Sup man I checked out your stream and it was really cool with you running original hardware.I was a able to get an image from the GBS to a monitor directlyLet's find where in the chain there is an issue - do you get an image from the GBS-8220 when plugged into a monitor directly? Furthermore, is this with GBS-control, or the stock firmware? The GBS-8xxx series is not known for great compatibility or performance when stock, so it would be good to determine if that is working correctly first.
oh snap, thanks man!Sup man I checked out your stream and it was really cool with you running original hardware.I was a able to get an image from the GBS to a monitor directlyThis was done with stock firmware, and has been working for me for a while now.Let's find where in the chain there is an issue - do you get an image from the GBS-8220 when plugged into a monitor directly? Furthermore, is this with GBS-control, or the stock firmware? The GBS-8xxx series is not known for great compatibility or performance when stock, so it would be good to determine if that is working correctly first.
still fixing a lot of stuff on how it looks and getting more stream equipment, like a mic and webcam stuff.
we are gonna stream again 25th/26th this September. few friends are coming over for some 3rd strike action!
Awesome brother I will be there to support if I am not out on mission.
Thx,
Kelly
I got mine a while back yes.Are people here getting their "orders"?
I'm not sure why this is in "quotes".Are people here getting their "orders"?
Great thanks for the update, appreciate itBeen held up because I have run out of the printed boxes. While those will be seeing a redesign in the future, I'm finishing off this batch with an order of that same type of box in order to move things along.
The list is up to date on page 16.I would like to be added to the list plox
@zionfarm seems to have gotten his.If I can find out who got their last order I can eliminate quite a few names from the beginning.
