Kujako
While I am waiting on some parts, I wanted to power up a 246 and a 256 system to make sure they work. I have a bench power supply with the required voltages, but not sure about the power pinout on the systems. Also, and possibly because I'm tired, I cant remember if hooking the same 12v (as an example) source to two pins on the Namco with different grounds is considered parallel or not and thus will result in a voltage drop... put another way, as I think there are two 12v pins on the Namco do they require different 12v sources?
