Big_P Big_p
First post after a bit of time off forums. I was working with @ImportantBet on an adapter to allow fitting of a meanwell RT series PSU into a Taito Egret II and wanted to give a bit of background (and ask a few questions). The Taito adapter listed in his sales thread https://www.arcade-projects.com/threads/egret-2-meanwell-rt-series-psu-adapter-pcb-pre-orders.36204/ came about after putting together a similar adapter for the Exceleena. This was required after finding that leaky caps had totally corroded the original PSU and having an almost perfect wiring harness i didn't want to just hack it up. After showing the results it was asked (I think half joking half hopeful) "if one for the Egret II was next" and what resulted can be seen in the FS thread. He did a great job of putting together the adapter and fully testing it so I 100% recommend getting one if you need to replace your PSU or just want a backup.
Anyway the main point of this post is to show off a similar solution for the Exceleena PSUs. I also designed up a 3d printed bracket so the meanwell and adapter PCB can fit in the original PSU 'box'. The picture of the fitted mount shows an earlier (green) revision of the adapter PCB, with the latest (purple) revision including a switch to select the rail (5v or 12v) the voltmeter is displaying and being the same width as the meanwell PSU (and the Taito Egret II adapter). I have a few of these and can get more made up if there is any interest.
I have been working on a similar adapter for the Astro City and Model 2 PSUs but have hit a wall in finding board mounted connectors for these. If anyone knows where I can find these that would be amazing.
