Dk310
Rocket, for the v1 or v2 red, how do you know just by looking at the cab? The red speaker grills?
As far as I know its only the X2Ok, thanks. I will have to buy one on Amazon. I'll let you know.
Is it the same thing with RE2 ? Do I need a DVI-I to DVI-I cable ?
Hi Rocket, I removed my monitor and strangely it turned out to be a Weiya it’s original as it has the buttons etc under the lift up cover by the card reader. Noir is dated 2007.A lot of folks on the lindberghs have been replacing the monitors with better ones. I havent heard of this being done with noirs. I would suspect with a noir you could hide the monitor much better with the shell. I think thegreathopper is going to have the answer with the lg experiment
that looks so smooth.Here you go, after.
That lg looks great how did you mount it and what is the model number of the lg? Can we get pics of the mounting?Hi Rocket, I removed my monitor and strangely it turned out to be a Weiya it’s original as it has the buttons etc under the lift up cover by the card reader. Noir is dated 2007.A lot of folks on the lindberghs have been replacing the monitors with better ones. I havent heard of this being done with noirs. I would suspect with a noir you could hide the monitor much better with the shell. I think thegreathopper is going to have the answer with the lg experiment
But now has an LG dated March 2020, took a few hours to fit but looks great will post a picture later.
All the games on my X2 worked fine on the Weiya monitor and the new LG, basically they all work fine.i'm still looking for one, john's not got back to me yet and nobody else is selling anything, but I decided to hook up my dell monitor just to see what the difference would be from my naomi cab, I tried it first as standard and everything worked fine but nothing special, then I changed jumper 2 to on and tried again, it does make a big difference in the quality, but, not all games would work, some did, some just hung, but most went back to menu screen, i'm presuming it's down to the resolution, but will this be the same when I get the Namco cab?
I fitted a LG 32MP58HQ, here is a pic of the Wei Ya monitor that was originally fitted.That lg looks great how did you mount it and what is the model number of the lg? Can we get pics of the mounting?Hi Rocket, I removed my monitor and strangely it turned out to be a Weiya it’s original as it has the buttons etc under the lift up cover by the card reader. Noir is dated 2007.A lot of folks on the lindberghs have been replacing the monitors with better ones. I havent heard of this being done with noirs. I would suspect with a noir you could hide the monitor much better with the shell. I think thegreathopper is going to have the answer with the lg experiment
Also what was the model# on the wei-ya
I wonder if it’s the cable I was using then, instead of using the dvi adapter to vga I just used a dvi to dvi cable, everything worked if I didn’t change jumper 2 but the older games don’t Id I doAll the games on my X2 worked fine on the Weiya monitor and the new LG, basically they all work fine.i'm still looking for one, john's not got back to me yet and nobody else is selling anything, but I decided to hook up my dell monitor just to see what the difference would be from my naomi cab, I tried it first as standard and everything worked fine but nothing special, then I changed jumper 2 to on and tried again, it does make a big difference in the quality, but, not all games would work, some did, some just hung, but most went back to menu screen, i'm presuming it's down to the resolution, but will this be the same when I get the Namco cab?
