Namco Noir HD log
I just got a pair of Noirs as well so figure I'll add to this thread if that's ok. I run them in an arcade with ES3s. The GPUs were overheating and crashing the game so I 1) removed the top of the case of the ES3 and 2) added fans to blow more heat up the smoke stack. I'm using the existing empty fan headers of the ES3.
Cool! That's smart. I've been thinking about adding more fans to my setup, as well. Right now though the temperatures are very good with the swapped in/out parts so I'm going to see how it does before I make any more moves.
No major updates on my end! I cleaned out the inside of the top shelf and got it stripped all the way down to just be used as a shelf. It's really clean now!
I did however throw these cute pacman statues on top. Couldn't think of a better place for them to live.
For next steps, I am going to likely put an ethernet passthrough in the rear of the cabinet. Right now it's running in through a hole in the carry handle on the bottom half of the cab. I'd like to clean that up a bit. There's a good chance I do an HDMI in/out at the same time, and maybe figure out how I can get a surge protector inside this guy..
For a surge protector for the monitor and PC, you could buy some IEC connectors and cut the end off a surge protector, solder on new connector and use the power cable you have in the cab already.
IEC connector
Why not use the bottom access panel? That's what it's for.
Managed to get my 3d printer back up and running, and to match the mounting pattern of the Bana Passport reader. Working on a fun little project to replace it on the control panel. Will have more to show as I get farther on the project. 🥲
Alrighty, so this is my solution to get back the buttons i'm missing with a 6 button layout.
My print sucks (sorry), but functionally it's going to be a huge add to the machine.
I'm planning to get a better printer - maybe then i'll sell them or something.
I am very very new to the Arcade owning scene and this looks awesome! But I have a question regarding the IO connection; did you wire it with Brook UFB or are you using the original JVS (not sure if it is JVS sorry)? does any PC work with JVS IO? sorry I am really a noob and I just got my first SEGA PRas 3 and I am trying to hunt a NOIR next
Acabo de adquirir unas Noirs, así que creo que añadiré algo a este hilo si te parece bien. Las uso en una sala de juegos con ES3. Las GPU se sobrecalentaban y bloqueaban el juego, así que 1) quité la parte superior de la carcasa de la ES3 y 2) añadí ventiladores para disipar más calor por la chimenea. Estoy usando los conectores de ventilador vacíos de la ES3.
Buenos días. Los ventiladores que aparecen en las fotografías de qué medida son? Por otra parte, ¿están colocados en la parte lateral donde la negra tiene varios orificios para sacar el calor? ( si estás sentado frente a la noir jugando me refiero a la parte lateral izquierda que tiene si no recuerdo mal 3 cuadrados con orificios. )
Estoy restaurando mi noir y quiero poner varios ventiladores noctua tanto el de la parte trasera del monitor que será un noctua de 120mmx120mm y luego quiero añadir laterales para que puedan sacar todo el calor hacia fuera. Muchas gracias
Quiero poner los ventiladores en esa zona marcada de blanco. Querría saber ya que no tengo la noir actualmente conmigo, si entre la zona de orificios que marcó en blanco y las chapas donde se sitúa la madera para luego introducir un PC o un type x cuanto espacio hay para saber qué 3 ventiladores puedo poner. Sé que deberán ser 120mmx120mm pero el grosor puede ser importante por qué depende del espacio entraran todos o solo algunos modelos concretos. Espero respuestas, graciasss!!!!
