Nanao 2930 - no screen with neck glow
Yep. And then you have to check again with the PCB attached to get a more proper reading since the PSU will now be under load. How much of a load depends on the PCB.
Ok so without a board I'm at 5.17 VDC and 11.8 on the 12v pins I guess I should probably dial back that pot on the power supply eh?
Retested the chassis today. No HV period coming to the anode, neck is glowing B+ is at 180V DC.
I tested a spare I have and will be preparing that one to ship out to JSN as a replacement.
If I ever fix this ill try to remember to post the fix here.
I also dont recall hearing the deflection running so maybe there is a issue in the deflection on this board and its shutting the HV down?? not sure.
If you refer to one of my videos posted earlier here I thought I was getting a hum… is that not deflection?
Yeah it should be? I dont recall hearing it today at the warehouse cause I didnt take a mental note to check so im not sure tbh its gonna be a deal with it later situation. These next few months for me are getting busy busy
