Always what? Are there more than 2 fuses?Always. Also check your cab interlocks
Not sure what you mean by cab interlocks. If its the door lock switch i have that bypassed.
You just wait till the day that zip tie has loosened *ever so slightly* and then you spend an hour panicking and chasing shadows because you can't figure out why the cabinet won't turn on. I think just about every Blast owner's gone through that at one point or another.Not sure what you mean by cab interlocks. If its the door lock switch i have that bypassed.
@GeekMan1222 had it set before shipping. I’ll try. All these problems arose after i pulled it out of the fedex package and connected it to my cab.Sorry thought you meant in reference to cab fuses. You measure the b+?
What are your dip settings 1 off, 2 on and 3 off?
Wait a second this doesn’t make sense does it?All on actually. Was working before like this.
The mister is is set to be sending 15khz signal
I had that exact same issue in one of my blast cities. I had to send to PNL and they fixed it. He just told me it was the HV daughter pcb board and that he replaced components on it. I couldn’t get anymore info than that and not even sure if what he told me was accurate. I didn’t really try and pry more info from him cuz I was just just happy that the monitor worked again.View: https://youtu.be/QVxwVvYyYTw
Here’s a visual rundown of what’s happening
Here’s also a pic of the neck which you couldn’t really see in the video.
This is the same chassis you worked on in other thread? Seems like you did a burn in test. But I agree research the hv areas. There are a couple of hv shutdown and power issue threads. Also the ms2931 manual gives general guidance. Checking the power circuits etc, most likely the part numbers referenced would be off.I cant remember if you had 2 blasts or not but if you did you can just swap the remote board and cable and rule that out right away if thats a concern?
My guess is something funny going on in the HV circuit but unless you pry around the board alot more its hard to just say its one thing.
BlinG may have a point though those HV regulating daughter boards can get cranky its possible after the recap that another component that was already tired or stressed out died? Maybe a passive like a resistor or something like a diode.
