Naomi 1 early revision board - Doesn't boot, black screen
MagicianLord77
Montevideo, Uruguay
Hi guys, I find myself with this Sega Naomi board that has let me down. It's my first and only Naomi board, I know it used to work, then was stored at a not very dry place for around 2 years, then came to my hands to seem to perfectly work for a couple of hours then hang in game - screen froze all of a sudden, and never turned on again.
It's an early revision with an amount of factory wire patches, resistors, etc., came with Virtua Tennis.
When I disassembled it, it seemed like it had never been opened before, it was very dusty, cleaned it up.
Filter board looks fine, no traces burnt.
Took out the old CR2032 and the supercap just in case, no leaks found. I left the case fan disconnected.
So, current status is no boot, no video, no audio :(. Leds turn up, fan spins, and emits the square wave at its yellow pin (around 160hz).
Verified the contents of its EPR D 21577 BIOS chip with mame -romident, all good.
Checked voltages at the filter board: 3.38, 5.05, 12.42. Good values right?
Also at the test points the board: 2.05 (SH IN), 2.54 (2.5V), 3.35 (3.3V), 5.02 (5V), 12.40 (12V).
Some few capacitors used to look a bit swollen or with a white kind of rust, so ordered a full set using the retro hardware capacitors list and replaced them all, found that almost all had quite high VLoss % / ESR compared to the new ones, an average of 8 times the value of the new ones. Only the big "ELNA" ones were in very good shape. Anyways, after the effort of replacing every electrolytic capacitor, nothing changed.
So now I find myself not knowing what to do next, I've got a 200Mhz scope but I'm not sure what could I measure. Could the RAM be the culprit? should I go and replace the 4 cpu SDRAMS or the 8 graphics ones too? if not, what else?
Any suggestions appreciated! Attached front and back pics of the current state of the board
Thanks!
I’m having the same issue. It plays sometimes and then it freezes after the Naomi screen sometimes the Sega screen sometimes the game screen
Did anyone attempt to blindly replace the usual RAM? IC16,18,20,22?
I got two of these revisions and they do not boot. Fans spin, voltage is there.
I plan to replace all rams with new ones, just haven't been able to do it yet. I've purchased these, hopefully they are the right fit:
  • GPU: IS42S16100H (512K Words x 16 Bits x 2 Banks) (16-MBIT) - confirmed as good for graphics ram
  • CPU: IS42S16400J (1 Meg Bits x 16 Bits x 4 Banks) (64-MBIT) - ??? I think it could work, at least my Naomi has Samsung KM416S4030BT whose datasheet describes them as 1M x 16Bit x 4 Banks Synchronous DRAM
I'm also interested in knowing if changing the RAM solves this problem. There are many Naomis with a black screen.
Any updates?
I'm sorry I got caught up with other stuff where spending time might be worth it more. I've become hesitant about replacing all the RAM, since I also got a couple other Naomi boards with the exact same issue, and recently I've seen that they could also suffer from cold solder joints in the BGA ICs just like Naomi 2s.
I would prefer to rule out first if it gets fixed by reballing before spending the effort of replacing all RAMs, but haven't found where to send them yet
