Naomi 2 HDMI
citrus3000psi
United States
I started working on this a few weeks back.
I just finished the flex cable and ordered some proto units. Audio will need to route to this flex cable as well. I'll make a small little PCB that mounts on the DAC. You could solder directly to the DAC legs, but I will put some series resistors on this QSB.
There will need to be some special firmware changes. The DC runs at 525 lines where as the Naomi 2 is 530 lines. I'm also not sure if its worth the effort to tie into the JVS IO inputs. I may take some signaltap logs of the inputs. The maple bus will work out of the box and all settings can also be changed via wifi web terminal. So its a latter priority.
8o 8o A dream come true! Definitely in for at least 2 of these.
Awesome!
Also parroting the question about if this will work with Naomi 1....
Now @Darksoft and @Apocalypse does this mean a multi cart should be looked at a little closer? I would have also tagged @brizzo, but he's got a shit ton of other stuff he needs to deliver first!
I believe its just a matter of redesigning the flex cable between models...
Nice work @citrus3000psi! And in time for Christmas!
