Hi! I’m a newbie to JVS systems and the biggest sticking point in my project currently is that I need a way to power a NAOMI 2 with a NetDIMM without a cabinet. This is apparently a very power hungry set up and I’ve seen two main options:
1. Sun PSU. The most reliable solution although these units are getting up there in age and are expensive. My question here is if anyone sells an adapter so I can plug it into the wall or a power bank or something.
2. ATX PSU. The adapters for these seem to be produced frequently enough to where I can find multiple sellers, however I’ve heard doubts concerning this specific solution as the voltage from the PSU’s 3.3 and 5V rails needs to be in a specific window for the NAOMI to not get cooked. A quality PSU would work in this instance but I’m wondering what models you guys would recommend.
I have lurked for awhile and can’t really decide on what to do, so I figured I’d just ask you guys directly. Thank you!
Edit: Got my PSU question squared away but did not want to make another thread when my next question is in the same field of knowledge.
https://www.arcade-projects.com/threads/naomi-2-netdimm-power-supply-options.25113/post-373033
