if you cant find it, give me the game part number and i'll sort it
Yup, I'm an idiot. I can't even burn an eprom properly. I tried using the information on this page to burn even a simple naomi 1 bios and couldn't do it.
I was using this site to try and help explain and walk through how to do the eproms:
https://mousebitelabs.com/2019/09/02/27c322-160-programming-adapter/
It clearly didn't work or I misunderstood something, here are my steps i took just to do the bios file because the game epr didn't work either:
1. Take the bios file and use hjsplit to split it up into 512kb rom files
2. Using XGUPro set the IC chip to AM27C4096 and then set the settings for programming of the 27c322 ic and then I open the first rom file into the buffer.
3. Then, using the website I mention above, I set the dip switches to the first rom file position for 27c322 ic. So, all are set to off.
4. Then click Program. It programs and verifies it.
5. Open Rom 2 into the buffer.
6. Change the dip settings to the rom 2 setting shown on the link I used for reference. So that is 3 set to on.
7. Program and Verify
8. Open Rom 3 and repeat.
9. Open Rom 4 and repeat.
10. Only 4 Roms were created with HJSplit at 512kb so I'm done. Right?
11. Test if bios chip works and it doesn't.
I'm clearly missing a step not just for the bios but also for the epr rom since neither work. Was I supposed to clear the buffer after I programmed each one? I don't know.
