not compatible with certain monitors or TVs.
is it known why exactly this happen and how to fix this problem ?
The problem can be corrected by enabling a feature called DDSP (Digital Display Sync Processing) on a Extron 580xi.
Far as I've been able to tell both Naomi and DC output an off spec version of a true VGA signal.
OSSC has no issues with it, and analog monitors don't seem to have any issues with it.
Digital Sync Processing (DSP) is a proprietary Extron technology that addresses potential issues with
sync in RGB computer-video signals that could compromise, and even prevent, proper video display."
But if you're bringing a Naomi setup to your local it's really handy to be able to just plug it in and have games ready to go. No extra boxes to worry about, less cables, less setup and config.
So lets advance time a bit... To the far off year 2035... Are you going to be connection a 1080p Naomi to any display then?
At the rate we are going we'll have hit 10,000k displays by then, and your 1080p is going to look just as shit (if it even syncs) as 480p looks on a 4k today.
You are going to be re-modding these same consoles every few years, over and over to keep up with the times.
That is so ridiculously wasteful it totally negates any positives attained by the purity of the source video.
As I said to
@nam9 we should be searching for the best pre-amp location to tap the purest source vdieo we can from these original boards...
But that is where we MUST STOP! The scaler MUST ALWAYS remain totally/fully upgradable to match with the changing times of display tech.
Sorry to be a douchebag, but anyone who says otherwise is just wrong, and that is the last I'm ever going to say about it because I WILL NOT entertain any argument to the contrary. You are wrong, I said so, and that is IT.
