Naomi went from booting just fine, to fan no longer even spinning.
NewVegasBlues
United States of America
I just got this setup, been troubleshooting for a few minutes now, had to power cycle a few times, now my NAOMI is no longer even spinning its fan. I'm using a ATX power supply.
atx psu's if they aren't quality might not give u the correct voltage needed for the naomi. they are very very picky with voltage, so there is that, but then i saw this on a different forum..
Error 31 is a generic netboot failure. Error 22 means bad connection between the DIMM and the board.
For 22, you want to take a look at the daughterboard on the DIMM; verify the connections are nice and tight, and clean all of the connectors. Then, do the same on the mainboard. Try again. If it continues to fail, you have a bad DIMM."
so if you have the 22 error do what it says and clean it out.
How exactly do I even open the DIMM up? Ive gotten a few screws out but its still having a hard time getting out.
you got me homie. my netdimm setup works so i haven't had to tinker i don't think its that difficult though but i can't help more than that.
You should measure voltages. There's no point in troubleshooting it further before that.
Ontop of that, the green light is showing on here.
