Rafo
Hi all.
This is a tough one... I guess.
Here is the situation.
I have this naomi REV.A mainboard. Higher resolution here
Its looks pretty clean to me except fr some soldering next to BIOS that repairs a cut in the track, nothing to report on the aesthetic side,
Before you ask, yes, the supercap is brand new, although not in the same package as the original (which was fine, BTW)
It does not boot : no display, no sound. The only thins that happens is when the monitor is already on, and in standby mode because of the lack of signal, when I power up the main board the monitor snaps out of sleep mode but only to get back there after a few seconds.
LED1 and LED2 are lit normally.
Tried another filter board, different BIOSes, same result.
What bothers me is one of the voltage testpoints on the main board :
As you can see, 3,3V is not 3,3V anymore (even on the PSU output) as long as it is connected to this particular main board.
And before you mention my PSU, please note that it powers my Naomi2+NetDIMM and my Triforce Type 3 perfectly. So I think it rules out the PSU for causing this.
As you can guess my electronics knowledge is quite low, but I'm pretty sure this can be fixed and is not a big thing to deal with.
My (wild) guess is something, maybe in the PQ7RV4 area (RG4 on the mainboard), is messig with this voltage and makes it drop : not to zero, but low enough to prevent 3,3V powered chips from working.
The RG4 itself is already replaced, as i had a few around (the original one did not seem in good shape to me, so I thought this was the one causing this.... but it seems it's not (or not alone).
I'm not sure what causes this 3,3V getting lower, someone here has quite an experience of this kind of issue to help finding out what is happening and/or how to fix it. Again, I'm sure it's nothing big.
Of course, I'm ready to answer any additional question or perform additional required tests which could help to narrow the research down.
Any clues ?
Code:
12V 12,11V
5V 5,11V
3,3V 2,55V
2,5V 2,43V
SH IN 2,011V
Any clues ?
