Kujako
So pulling my 25" CRT from my MVS "big red" so that I can work on it, planned on putting in a 19" SuzoHapp CGA/VGA LCD for the time being so I can keep using it. Now this cabinet has a JAMMA switcher and seven different arcade boards in it, including a MVS-2F and MVS-1B. Wiring is still MVS, using adapters for the JAMMA boards. I hooked up the LCD outside of the cabinet to test, and all boards work EXCEPT the two Neo Geo's. On both of those, I get no signal.
Any ideas? Again, works with a Sega 16b, CPS2, Sega STV & PGM. Not working with Neo Geo MVS (and it looks like also not working with a Namco 256, not tried any others).
I can try using the VGA port and 31khz with the devices that support it, and I guess I could scale CGA to VGA... but this is supposed to be temporary. So there's limits to what I want to try.
OSSC) the biggest issue is monitors that won't display anything but 60hz (making that freesync LCD pretty much a requirement for use/NOT optional).
