hjrcustoms
Hi Everyone,
I am currently in the process of setting up a Naomi 2 with netdimm and trying to get the netbooting working. My inexperience may be playing some part in the process failing and just after some assistance.
Netdimm version: 4.02 - both 8 & 6 pin connectors from an external power supply (Meanwell QP-200-3A - 5v/15A, 3.3v/15a, 12v/6a) and the Capcom I/O for jamma conversion.
I have successfully booted with piforcetools, however the machine reboots shortly after loading with ERROR 33 - I have tried burning a zero pic but this doesn't appear to be working (likely my fault as its the first thing I've tried to burn).
I've successfully used transfergame.exe to load game to netdimm - this reboots to ERROR 31, then shortly after reboots to ERROR 33 - no security/zero pic again I assume.
In the meantime I'm trying to use the python script naomi_boot, till I can figure out the rpi/zero pic issue.
The process appears to start the transfer process but then fails with the below output:
C:\naomiweb>naomi_boot.py PowerStone2.bin
connecting...
ok!
Traceback (most recent call last):
File "C:\naomiweb\naomi_boot.py", line 221, in <module>
DIMM_UploadFile(sys.argv[1])
File "C:\naomiweb\naomi_boot.py", line 132, in DIMM_UploadFile
DIMM_Upload(addr, data, 0)
File "C:\naomiweb\naomi_boot.py", line 68, in DIMM_Upload
s.send(struct.pack("<IIIH", 0x04800000 | (len(data) + 0xA) | (mark << 16), 0, addr, 0) + data)
socket.timeout: timed out
The Naomi just shows a blinking "Now Loading" message and doesn't get any further.
Thanks in advance,
Ben.
connecting...
ok!
Thanks in advance,
Ben.
