@frosty Wow that looks great! Good job!
I wasn't planning on sanding/painting etc...but seeing your results has me thinking I should.
If you don't mind me asking, what did you use to sand it down and did you use a primer as well? Sorry, I'm new to all of this.
cheers
Nice! Thank you for the advice, i'll give it a go!Just use something like 400 grit - nothing too abrasive. You could also use a medium (maroon coloured) Scotchbrite pad, depending on how thick you apply the epoxy.
Just get it down as flat as you can on the front - obviously doesn’t matter too much on the back, unless you’re OCD about that sort of thing! Provided it’s reasonably flat, the paint and clear coat will mask it
