Hi there AP community! Got this NAC towards the beginning of the year, already have the restore over on Aussie Arcade. Wanted to share the adventure here too.
There are some talented people here on AP , I hope these restore posts are worthy.
Pre-Paint
This poor thing had a hard life here were the problems
-Monitor anti-glare/static coating very patchy all over
-Rust in and around each door
-Surface rust on the monitor frame
-Surface rust on the power supply
-Very filthy inside with nuts/bolts/wire off cuts/random junk like a cigarette packet lolly wrappers and broken quick disconnects all kicking around in the corners and wedged behind the transformer.
-Drink stains down both sides of the front and rear inside shell
-AC wiring looked messy and unsafe and no inline fuse
-Jamma loom and rest of the wiring just filthy everything caked in grime
-One of the mounts where the inlay bolts to the CP was broken off
-Wiring coming off the underside of the Jamma connector worn to bare wire from rubbing on the rough edge of the PCB mounting frame (about 8-9 various wires needed to be spliced here and soldered and heatshrinked)
-Missing screws all over the machine
-Back AC panel was badly bent in one corner in order to access the back AC panel from the rear of the machine it looks like someone had just forcefully bent the panel back because they couldn't be bothered getting a tamperproof tool to get it off correctly.
-The only things that were earthed/grounded were the coin door and coin box, all others non existent & under the CP non populated grounding 2 pin AMP connector
First job was the monitor, the anti-glare/anti static coating had been rubbed off in places all over it looked very unsightly. Went and bought a cheap car buffer from supercheap auto, it came with a terry towel sock pad/microfiber socks and a buffing sock. Got some Auto Glym windscreen/glass polish while i was there and got into it. Dampened the terry towel sock and liberally applied the Auto glym. With quite firm pressure i went over the face of the monitor multiple times until i could see all the purple/pink residue starting to come off. Kept rinsing the sock and repeating until it was all off and then with the buffing sock gave it a final once over, took about 20mins below is the result.
The monitor face looked very clear and flawless now I was happy, the Auto glym even took the swirls and light scratches out of it.
Next wife and I put the cabinet on its back and pulled the CRT and chassis, brushed the entire thing down to remove all the soot/black build up and using a lot of damp paper towels deep cleaned the back of the CRT.
![4.jpg 4.jpg](https://www.arcade-projects.com/data/attachments/57/57630-23af0ecccf5aef45b156a9321316c629.jpg)
![5.jpg 5.jpg](https://www.arcade-projects.com/data/attachments/57/57631-9521065d03bde3fb2988e010fc09a2ea.jpg)
![9.jpg 9.jpg](https://www.arcade-projects.com/data/attachments/57/57604-f0431200e6603a4294dcf6d4649456d6.jpg)
![8.jpg 8.jpg](https://www.arcade-projects.com/data/attachments/57/57601-570e132bf451fcc2d37eedb281df81ac.jpg)
![3.jpg 3.jpg](https://www.arcade-projects.com/data/attachments/57/57603-5412406f87247305052450b4f40d6284.jpg)
With the monitor and chassis cleaned I was itching to get it cranked up , re-assembled and did and initial power up. It looked quite vibrant and colours were good pre-colour calibration was happy the monitor didn't look to tired at all.
The cabinet stayed like this for a few months now in the living room in this state, I got irritated and decided it wasn't near good enough.
Pre-Paint
