winteriscoming
I've had success with this script for bi-directional sniffing purposes:I also am getting a second serial port tonite and am going to try and use a "bridge" piece of software to see and log all comms between the devices.
https://github.com/pklaus/jpnevulator.py
Even if you just sniff one-way for now, if you get some logs from the game during play, I should be able to tell if the commands have holding force. Basically, based on my notes, the 5th byte in the command packet needs to be 10 or higher for noticeable holding force. If the game is not issuing commands with sufficient holding force,then my notes indicate that could be due to something going on with the POWER line or how the board is responding to changes to it.
