mathewbeall
Hi Folks,
I apologize for what may potentially be stupid questions... I have a decent amount of experience with JAMMA boards and such, but just picked up a Maximum Tune 3 cabinet (no game board) this weekend from an AP member. I also picked up a Chichiro type 3 at the same time.
Cabinet is very clean, monitor isn't working right now, but I have a LCD hooked up via a converter board. It has a security key with the number "253-5509-5101" which seems to be a maximum tune 1 pic. I have a raspberry pi set up for netboot a couple of games to test with.
Maximum Tune 2 - it loads, I am able to go into the game *test* menu, it *usually* doesn't freeze, although sometimes it does. When it does boot, it gets stuck at "handle check - checking" and is also looking for link PCB 2-4. I didn't see anywhere in the config of the game to tell it that it's a single cabinet.
Maximum tune 1 - it loads, Handle Check is "ok" but then it says "please call an attendant, Wheel error occured E20"... I do see the wheel moving however, during the test.
So, here are some generic questions.
o First time using a JVS racing game setup - can I reasonably expect any JVS racing game to work in this cabinet (I have a naomi2 setup with netboot as well)? Or is this one really only going to work with Maximum Tune 3 (which I don't have the board for)?
o I am pretty sure I need a zero key PIC to netboot other games besides what I have the chip for, although its a bit confusing to me that they start - how can I get a chip?
o the volume doesn't seem to be working at all - it's full volume when the system boots, regardless of what volume knob (which is behind the coin door) is set to - is this normal?
o There is a small 8 pin adapter down by the the usb, video, RCA cables - in looking through the service manual for maximum tune 3- it seems like this plugs into it - with a Chichiro - where should this plug into?
Thanks in advance for any help you can give!
Matt
Matt
